Shinki - Now in LEGO
Post by Caterwaul » Fri Apr 25, 2014 11:14 am
No idea if I'll ever build them with actual bricks.
Don't know if it's even possible, as it uses some odd colors.
But here's something I've been working on in LDD. Consider it a Work in Progress
PS: The size discrepancy is due to cropping. They're both actually the same size.
Image Image
Re: Shinki - Now in LEGO
Post by Caterwaul » Fri Apr 25, 2014 4:54 pm
And one more, cause I'm bored.
Post by Klinkin » Sat Apr 26, 2014 12:54 am
Nice, but I have to wonder if you made them a bit closer to Shinki-size would they have more articulation? So far they look pretty limited (though props for an abdominal joint that real Shinkis kind of lack).
Post by Caterwaul » Sun Apr 27, 2014 3:27 am
Actually, they're a bit big. I made them for use in Mobile Frame Zero. (It's a mecha minis game where you build your units out of lego)
At the moment they're averaging about 15 studs high. Most minis for that game should top out at 12 studs high.
