• View topic - DLC shinki's?
DLC shinki's?
For help & discussion of Battle Masters.
Re: DLC shinki's?
Postby DurpyDoll » Fri Mar 16, 2012 10:33 am
All my girls. :)
DurpyDoll
Re: DLC shinki's?
Postby OshareKeiji » Sat May 19, 2012 2:16 pm
OshareKeiji
Re: DLC shinki's?
Postby Zenislez » Sun May 20, 2012 11:12 pm
Judging from the combined personality of the original and DLC shinkis, I think I understand now why the master (you) only activate and bring along one shinki at a time.
Because if all of them active at the same time, it wil be war between your own shinki.
Even if peaceful, it will be a cold and fragile peace before something or someone make a move before war breaks out.
Speaking of Strarf, I find it amusing that she is one of the few shinkis dare enough to insult her master (you). Yda also sometimes insult her master, while Tsugaru sometimes give sarcastic remark to her master.
"Motto Shiawase Ni Naru"
Zenislez
Re: DLC shinki's?
Postby Shikaze » Mon May 21, 2012 6:07 am
While the others guilt you to do things their way (Mary Celes), go behind your back to do their thing (Lirbiete), make demands of you (Renge),..... not sure if Strarf isn't indeed one of the mild one.
Shikaze
Re: DLC shinki's?
Postby OshareKeiji » Tue May 22, 2012 2:01 pm
OshareKeiji
Re: DLC shinki's?
Postby Shikaze » Tue May 22, 2012 2:47 pm
Speaking of Tamako, her getting a good ol' cleaning from your Shinki is nearly in every scenario, it seems, with often hilarious results.
Shikaze
Re: DLC shinki's?
Postby OshareKeiji » Tue May 22, 2012 2:54 pm
OshareKeiji
Re: DLC shinki's?
Postby Zenislez » Wed May 23, 2012 6:08 am
Ah, I see. So the shinkis only turn their hostilities toward other shinki that is not yours and other female/girl (considering the story, I think the master is male. Special case for lir though, since from the past topic and that video, she sees everything that is female no matter what the species is as a threat) that is too close to you.
Thanks for clearing that up since the final section of the story (after the F1 tournament) still confusing for me due to bad japanese knowledge.
Hmm, BFF + comic foils + his image, I can't stop thinking that Jinpei have some qualities that resemble Yusuke from Persona 4. Probably just me.
Zenislez
Re: DLC shinki's?
Postby OshareKeiji » Wed May 23, 2012 7:38 am
Hostility is too strong a word. (though it holds true for a handful of them) Some exhibit varying degrees of jealousy towards other females and shinki outside the master's roster that try to get close. Story-wise, the master is indeed supposed to be male.
I agree though, Jinpei has a lot of similarities with Yousuke. He's a total goof, often appears at the most inopportune times and can be a bit dense. Still, he's a loyal friend and the starter gear that he gives you is a great help. It's also worth mentioning that he modded those himself (hence the +JO tag).
OshareKeiji
Return to Battle Masters
