• View topic - 3D printed guns!
3D printed guns!
3D printed guns!
Postby AlexG » Tue Mar 25, 2014 4:06 am
Finally got my Strarf MkII last Friday. When I opened her up I discovered a complete lack of hand guns, and thus decided to remedy the problem...through CAD and shapeways!
after about 6 hours worth of modeling this is what I have come up with:
The Cylinder (highlighted piece) is given clearance all around and a shaft with clearance such that, if printed properly, the cylinder will spin! although at shinki scale there is little chance the parts will stay separated...
I am currently waiting on the first prints from shapeways. They should be here around April 12th or 13th.
If anyone is interested in buying a set of these I'll probably make it for sale once I get any bugs worked out. A set of 4 revolvers at shinki scale in detail plastic costs $5 +shipping. Frosted ultra detail is like $7.50 +shipping. I'd also be happy to change the scale if you've got a different toy in mind, just let me know the required dimensions of the handle.
I'm also open to suggestions as to what I should model next, so give me some ideas! and it's not limited to only weapons either.
AlexG
Re: 3D printed guns!
Postby AlexG » Wed Mar 26, 2014 1:16 am
Thanks! that squirt-gun looks pretty good for a highlighter paintjob!
I'm interested to know, how sturdy is it? since I've had to change to FUD in order to get any semblance of detail through shapeway's thickness screening and i don't have much experience with FUD at such a small scale i'm wondering if they'll stand up to some use.
AlexG
Postby Shinki_Crazed » Wed Mar 26, 2014 2:28 am
Nice looking revolver you made there, do you think glasses would be possible?
Shinki_Crazed
Postby AlexG » Wed Mar 26, 2014 2:45 am
AlexG
Postby AlexG » Fri Apr 11, 2014 1:34 am
the prints have arrived!! :nanner:
i am quite pleased with them. they have a fantastic amount of detail for their scale and the spinning cylinder works beautifully! they are pretty sturdy with the exception of the hammer which will break if you push on it to hard. that was to be expected though. a few tweaks and they'll be perfect, just need to modify the grip, and thicken up the hammer a bit and they'll be up for sale for around $8 for a set of four.
the revolvers with a little sharpie & gundam marker:
(unfortunately, the one on the right is how i found out that the hammer is too weak...)
the hands with pointing but slightly curved index finger is ideal for the revolver, and fits perfectly and securely!
fresh from the box:
strarf showing off :rolleyes:
Thanks for looking.
AlexG
Postby astarothxi » Sat Apr 12, 2014 5:24 pm
Idk if this would be the right place to ask but what about weapons from other shinkis? ex: i have arnval tempesta and i would very much like to get her full arms accessories but don't wanna spend $200+ just for 6 parts. Would it be possible to print those parts up?
astarothxi
Postby AlexG » Sun Apr 13, 2014 3:11 am
AlexG
Postby astarothxi » Sun Apr 13, 2014 2:35 pm
Oh wow lol that does sound really complicated
astarothxi
Postby AlexG » Sun Apr 13, 2014 9:07 pm
CAD certainly isn't simple, but it's not as difficult as i may have accidentally made it sound :*) . Although as others on this board have discovered , it gets even trickier when you start trying to model smooth surfaces with lots of compound curvature, like a shinki's body or limbs, for instance.
AlexG
Return to Toy Discussion
