Shinki Accessories?
- Shinkis owned: 7
- MMS owned: 9
- Favorite MMS/Shinki: Altines
Shinki Accessories?
What accessories do you use with your shinkis? I typically use Re-Ment stuff or things I've made out of clay.
Re: Shinki Accessories?
I generally use accessories from other figures.GrannyNanny wrote:What accessories do you use with your shinkis? I typically use Re-Ment stuff or things I've made out of clay.
- bang04
- Shinkis owned: 7
- Favorite MMS/Shinki: Altlene
I got many accessories from 2nd hand market, some from Gashapon, some from miniature. I always go 2nd hand market because I can find many accessories with very low price (1-2$ each), but some of them need a little modify.
May be I will show them in my collections
- Adventwings
- Favorite MMS/Shinki: Asuka
Gundam stuff. The 1/144 weapons seem about the right size for shinkis (and figmas, usually), though you should check their scale individually for compatibility. Sometimes, the grip is either too long or too thick and you'll probably need to recast them in resin if you have the funds and skills.
- Mobius
- Shinkis owned: 3
- Favorite MMS/Shinki: Fliers~
I've also found some of the Master Grade body parts like MG Exia's legs go very well with Shinki - mainly just a matter of finding what works.Adventwings wrote:Gundam stuff. The 1/144 weapons seem about the right size for shinkis (and figmas, usually), though you should check their scale individually for compatibility. Sometimes, the grip is either too long or too thick and you'll probably need to recast them in resin if you have the funds and skills.
- Raffi von Lederhosen
For what it's worth, the lightsabers that come with the Kotobukiya RAcaseal Elenor fit perfectly into Shinki hands.
I don't have much stuff at the moment, but I'm planning to buy them some 1/12 scale dollhouse accessories for Christmas. A bed, a kitchen, some food, perhaps even a tiny computer. I'm gonna see what I can find.
- Klinkin
Kotobukiya's MSG line of weapons can work well with Shinkis. The peg size they use is slightly smaller than Shinki pegs, but any of their guns with handles can be held by Shinkis, and the pegs can be replaced with Shinki sprue sections. I've seen plenty of them in pictures around the forums (the gatling gun and impact knuckle/edge seem to be the most popular).
