• View topic - help on getting the 5 skills use achievement
Postby Rinkun » Mon Aug 23, 2010 8:28 pm
Any suggestion what is needed in order to unlock that?
Do i need to be very high level so i have like 2k sp or somthing in order to have a chance?
Rinkun
Re: help on getting the 5 skills use achievement
Postby PenPen » Mon Aug 23, 2010 10:13 pm
I can't remember how I got this one (I believe it "just happened" during one of the battle) but more SP definitely helps out on this one.
I think it's easier to do it with single missile + tension set then pick a right mission to fight.
Missile costs 50 sp, so with 250 sp your Shinki will be able to do at least 5 missile follow up in 10 turns. But the big challenge will then be, can you finish with a win on the 10th turn? (Not under attack, and not over attack... Which is hard.)
So yeah, get more sp will be a great help on this one...
Postby Rinkun » Tue Aug 24, 2010 5:08 am
Missiles as in the missiles in the spt shop?:(
also which page on the wiki talk about sense? i cant seem to find it :maochao:
Rinkun
Postby Sword » Tue Aug 24, 2010 12:55 pm
Since movement skills count too, it's really easy to get at higher levels. But yeah, you need a decent amount of SP.
Sword
Battle Rondo Edification Officer
Shinkis owned: 25
MMS owned: 6
Return to Battle Rondo
