You have to win a battle (not limited to official only) against your opponent that's wearing it.persocomsan wrote:oh, going to go check it out now, sounds fun, I can handle lag, I'm used to waiting for opponents anyway. cardboard box armor for the foot now huh, any idea how you get it?
I think... You just found a bug that grants you huge (max) amount of PP in one go!Kunoichi wrote:Something strange happened to me, I fought with three members, we lost,but one of the team members(a Smitherling) won 65752 PP O____O while my shinki and the other one only won 20 PP,this Smitherling used a dice as a weapon and this recovered the enemy's life twice(we lost because of this)...I dont know what the hell happened ^^U
...Sadly, luck is involved for this...
===== A few things I found during the event =====
1. The wiki page gets some good detail about how PP is gained.
2. It does lag less during the non-peak hour. (Still lags, but less.)
3. The event "Shinki Planet" follows the same game play of -- beat all enemies on this node, next node appears.
4. The battle is "team battle" style, up to 3 Shinkis from different players VS 1 npc.
5. Currently, it is not knowing if the Shinki listed in selection comes from (A) players that stand on the same node, (B) players that in the event, or (C) players that are online.
6. You can select a set, and/or change the battle command of Shinki that owned by other players - this will not affect any of their setups.
7. Like other team battle, there is no end battle comment - no AI, range sense, or closeness will be affected.
8. If your goal is to gain PP, it is *HIGHLY* recommended to put your own Shinki as the first runner up - because if Shinki from other player won the battle without your help, you WILL GET ZERO PP.
===== So, what makes your pick the other two Shinki? =====
Instead of level or rank, I guess I went with the cute looking ones (set 0 outfit helps, too...).
