• View topic - Maximum Burst's Questions
Re: Maximum Burst's Questions
Postby MaximumBurst » Thu Apr 29, 2010 11:05 pm
Postby Sword » Fri Apr 30, 2010 5:46 am
Tri-diamond builds usually are quite bad at the start. Their growth is painfully slow compared to 'normal' builds, but they usually do end up stronger than any level 150 build.
A more interesting question is whether 3 diamond is stronger than 2 diamond + black opal or something. I personally feel those two are too close to call up front.
Sword
Battle Rondo Edification Officer
Shinkis owned: 25
MMS owned: 6
Postby persocomsan » Fri Apr 30, 2010 10:54 am
persocomsan
Shinkis owned: 41
Postby MaximumBurst » Fri Apr 30, 2010 3:20 pm
So after realizing that maybe EX rank people would rather level up SP on me than defeat me, I went for the C-class route, since C-class people should want to win. Well, that didn't work out so well either because my unequipped Shinki was still able to beat someone. I was able to get 5 in a row eventually. I hope I luck out tonight. I can't believe the effort it's taking to LOSE. lol
Postby MaximumBurst » Thu May 06, 2010 3:12 pm
Okay, this time I'm wondering if anyone could give some suggestions for forcing DRAW matches at early levels. I'm trying to level up an SP-type Shinki, and I think the general strategy is to get DRAWs so that SP levels up, and when it hits the right levels (10-15), start winning using SP.
I'm using 3 Black Opals, and I want to shoot for something close to:
LP Lv.25
SP Lv.70
Attack Lv.10
Accuracy Lv.15
Evasion Lv.15
Guard Lv.20
I know that Black Opals have a chance to raise the level cap, but I'll just worry about that when I get there. One idea I had is to level guard to 20 so that I could use those two shields with the melee damage -50% and throwing damage -50% bonuses. Combining those with other similar bonuses would make my Shinki pretty sturdy. I think another option would be to try to go for high mobility. Moving out of the opponent's attack range can easily cause a DRAW.
Any success stories out there?
Postby MaximumBurst » Wed May 12, 2010 12:54 am
Here's a question: Is there a range sense for Guarding?
My Shinkis seem to be comfortable guarding ranged attacks, but they don't like to guard melee attacks. Is this one of those things that you need to teach your Shinkis through repeating missions over and over again?
Postby Sword » Wed May 12, 2010 4:53 am
Sword
Shinkis owned: 25
MMS owned: 6
Postby MaximumBurst » Fri May 21, 2010 10:40 pm
Postby PenPen » Sat May 29, 2010 10:50 am
Postby MaximumBurst » Sat May 29, 2010 12:01 pm
Ah ha. I knew it. I've been training my Shinkis to do well at multiple ranges. I can't decide if I should just keep it a little balanced or just go back to purely one range.
And it's broken up into only 3 ranges? Short = 0~100, Middle = 100~300, Long = 300~400?
PreviousNext
Return to Battle Rondo
Users browsing this forum: No registered users and 6 guests
